Air Hose Drain Valve
dapper
Don't know if it was pure luck, but the 1mm hole seemed to help on mine when restarting when hot. Just makes a mess of your runner board/flywheel cowl.
pasner
definitely theres a market opportunity for any dealer that wants to solve this problem with PWK carbs with a drain valve hose solution.
Hope someone reads this :roll: I´ll be the first one buying a couple of them 8-)
dapper
Fitting a reedvalve would reduce the spitback/starting problems and improve fuel ecomomy :roll:
pasner
actually lookin for a cheaper solution :oops:
