sealant
oggy
Just got it started,and got a oily leak from the down pipe joint even with scoot loopy clamp,does everybody use silicone sealent or different type,cheers
J1MS
RTV silicon. High heat silicone and high temperature sealant.
Use google to find it.
The RTV sealan. I am using now was bought by a mate, it's meant for sealing oven door glass and seems to cope with the heat of the expansion chamber well.
Cost about £6.00 for a tube that fits in a mastic gun.
oldbiker
J1MS, Is this the stuff that you are on about?
J1MS
tzr.steve wrote:J1MS, Is this the stuff that you are on about?
Similar stuff, the one I'm using is supposed to resist temperatures upto 300c I think.
Will find out what the make is and let you know!!!
goldeneye
use cheapo bathroom silicon from B+Q (no, i dont live there!) the one that smells of vinegar. smear loads round joint, clamp up, leave overnight, scalpel off excess. no leaks. about 3.50 a (massive) tube. ive used it for years, and it works, and easy to get, and cheap.
B&Q sealant for me as well :P
oggy
Thanks all :)
dapper
RS Components 283-426 Silcoset 158 up to 300 C
    Users browsing this forum: Google [Bot] and 16 guests
