Soppy idea or worth a punt
davidblythe
Work pressure finally easing up
anyway constructive or otherwise comments welcome
red ghost
Main scooter: lambretta gp150
hold the camera a little further away from the subject :frog:
oldbiker
If that is lockwire on cylinderhead nuts, I would not be tempted to try myself.
davidblythe
tzr.steve wrote:If that is lockwire on cylinderhead nuts, I would not be tempted to try myself.
Hi Steve
yes it is lockwire, can you explain a little more, appreciate your input
oldbiker
Sorry mate, but it just seems like more effort than gain.
I usually find that if the nuts are torqued down with decent washers they don`t come undone by accident.
J1MS
I think I would prefer to rely on a retorque after runninG up to working temperature and letting the engine cool. Then after 500 or so miles retorque again.
Train Driver
cezeta and sugarlump have been toying with an idea where you remove four plugs from your head cowling so you can get to the head bolts without taking everything apart
or is this like all new ideas it's been done before
Train Driver wrote:cezeta and sugarlump have been toying with an idea where you remove four plugs from your head cowling so you can get to the head bolts without taking everything apart
Now that would be a good idea cause its a pain in the ass having to retorque the head..
That would only be good for 3 of the bolts though wouldn't it
