Servetta CDI mounting
Hi, does anyone knoow how/where the series 80's mounted the CDI unit? I have just realised that there are no mounting holes on the rear tube although there is a bracket welded on the other side.
colin
Dimitrios_231
This is what I've done on a Jet that I have worked.
I've used an electronic mounting bracket.
In the place of original regulator,I put the CDI,
the regulator can be mounted in either side.
coaster wrote:Hi, does anyone knoow how/where the series 80's mounted the CDI unit? I have just realised that there are no mounting holes on the rear tube although there is a bracket welded on the other side.
colin
the original engine was points on that scoot was a year ago this week or was it 2 :?: was on ebay you rang me when i was on ten tors
colin
Blimey Steve how time flies :shock: it was 1 year ago. My original intension to use it as my London ride changed and now it will be doing the Euro in Gijon, I'll send you some pics 8-)
coaster wrote:
colin
no i will only cry :cry:
    Users browsing this forum: Baidu [Spider], Google [Bot] and 7 guests
