changed clip position and needle, still bogging down
lammysilver
28mm del, 42 clubman, old SR kit...
was bogging from idle - 1/4 throttle with:
105 main, 55 pilot, aq264, X2 (clip 2nd from bottom), 40 slide.
first i moved the clip up, leaned off a bit but not massively.
Went ahead and got an X7 and X13 needle, after trying the X7 then fitting the X13 (the leaner of the two) its still bogging down off idle.
I was thinking of trying a leaner slide and pilot maybe?
GP Kevo
The needle really comes into play between 1/4 and 3/4 throttle so yes, probably a leaner pilot jet will bring results you want.
joeythescooterboy
X13 is richer than the X7 not leaner kid.
Nemo saltat sorbius, nisi infanus est.
RinB
Dont forget the Slide acts in this part of the throttle in the progression period
Try a 45 -50 slide or take 0.5-1mm of the cut out
something strikes me as odd here...
if its a 28mm phbh carb then an AQ 264 would not fit in ...so maybe its an AV 264,either that or maybe you have a smaller PHBL carb...?
lammysilver
yeh X7 the leaner of the two, thats whats in there, and its a AV264... my fingers hit the keys a bit too quick! Apols for any confusion!! :D
To update i Just got a 50 pilot to replace the 55 and ill be trying that later.
Diablo
Lee have you tried adjusting your mixture screw?
Most bikes with your set up work well with an x7 needle
lammysilver
Cheers, ill be trying the leaner '50' pilot in there with X7 (clip adjusted to suit), then tweak the air/mixture screw , fingers x'd, sorted.
See how it goes then if needs be i'll take a look at the slide.
Read the post you put up Al, (motocross carb tuner), good one that, I also found this quite helpful... http://www.lambretta.co.uk/downloads/carbsetup.html
Eitherways Al all going good i should be up visiting soon mate.
eibargum
If all else fails your right to do what R in B [smiffy] suggest,s, only take 0.5mm off at a time, i had to do this on are lass,s 28mm BHPH to get it to run cleanly at the bottom end, but only after i,d try,d everything else, worked a treat :D .
Special X
45/50 slide (or modify the existing slide) 50/52 idle should sort it along with a bit of tinkering with the mixture screw. 105 seems a tad small on the main . . I'd have reckoned 110 was nearer the mark. Despite what many people will tell you the idle jet affects the mixture right through the range. Also check that the choke is seating correctly and closing right off as these carbs suffer from choke leakage which affects the lower throttle openings badly.
Hope you get it sorted . . there's nothing worse than nagging carb problems.
