GP side panel spring plate
- Suede Ed
- registered user
- Main scooter: SIL GP200
- Contact:
Problem-time to fit the above. However, the frame has had a repair, 'indian style' and the holes for the spring plate are not there so i must drill new ones. Have you got a picture of a plate fitted, or could you measure how far the plate is from the bottom of the frame. thanks
- sean brady scooters
- Dealer
- Contact:
FFS ..Jono I saw this post on LCGB...
its quite sad to see that you had no response on there...
just simply offer up the bracket ,mark the holes and drill....simple....
and just to help,the spring plate fixes directly above the lip..so bottom screw hole should be approx 6 mm above the frame lip..providing the repaired frame lip is in the right place...
- Suede Ed
- registered user
- Contact:
Thanks for that, basically a plate has been welded ( well, braised ) in place of the bottom half of where the reg plate goes, in between the lower holes for the reg plate (if your still with me!) I'll offer up the spring plate and have a look, didn't want to put it too high and have the panels do the 'skimming down the road' thing
. I'm not Jono BTW, just seen that post, coincidence.
- Andy Pickering
- registered user
- Main scooter: GP
- Contact:
Suede Ed wrote:I'm not Jono BTW, just seen that post
- Dealer
- Contact:
Then perhaps someone would be kind enough to reply to jonos post on the LCGB ,maybe put a link to this topic for him as i feel a bit sorry for the chap...hes had 95 views on there over 4 days but not a single reply..
thanks in advance.
sean
thanks in advance.
sean
- Andy Pickering
- registered user
- Main scooter: GP
- Contact:
- Dealer
- Contact:
thanks Andy ...you cheeky nephew
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
I'm not going there!.............................................
Scootering since 1968.
