Cheapo ebay ali kits, question
TS1-200
I know a lot has been written on these kits in the past, but I can`t seem to find the threads, I`ve had no experience of these kits, but a mate has asked me to fit a 185 one for him, I know the issues regarding cleaning up the ports, but apart from that are there any other things that need checking before fitting ? I assume its a straight bolt on ?
Keep on keepin on
lozmondo
Piston to bore clearance, ring gap and the head can be of dubious quality.
I have one thats been cleaned up and im very pleased with it. Compares favourably to a mugello...and over £200 cheaper! :D
RinB
The whole kit needs playing with...
Piston & rings are bad no good if you are thinking of stage 4ing
Ive done Dozens now but I change the pistons and rings and reprofile heads
Seen lots of the 186 200 & 225 kits go pop mainly due to rings breaking
soosh
So its worth buying one and porting it and getting a head done and a decent piston?
eibargum
soosh wrote:So its worth buying one and porting it and getting a head done and a decent piston?
By the time you,v costed that lot in you may as well buy the Muggy.
How much would a properly sorted kit set you back then? Ball park figure?
Doom Patrol wrote:How much would a properly sorted kit set you back then? Ball park figure?
£100 for sorting ports
£25 for a head
£50 for an Asso piston
£100 ? to buy the kit
£275 ish but could be less depending on the price of the kit. That's £100 less than a Mugello
eibargum
Thats true, but the muggy,s nicosil,d, take the muggy out of the running and go for the rapido, around the same price as the sorted ali kit i suppose, you pays your money and takes your choice.
£25 for a head
COL WERE CAN YOU GET ASSO PISTONS FOR THAT PRICE ,RAYS PED LIST THEN AT THAT BUT THERE WEB SITE HASNT BEEN UPDATED FOR ABOUT 5 YRS LAST 175 ONE I BOUGHT WAS 78 QUID
lozmondo
Except the Rapido is for a 200 casing ?
the ali kit is same construction as a Rapido, steel liner, ali fins.
Did Cobblesoul last weekend, hammered mine round the race track,racing a GP200 with NK pipe.Did over 400 mile round trip. Blew a head gasket but apart from that the cheapo kit performed very well, returned good MPG and if it does sieze oversizes available :D
I love nicasil kits cos of the peace of mind they can give. BUT a well set up iron barrel can be very reliable, let alone one with better cooling cos of its alloy fins. The money saved meant I could have a new GP race crank (60mm) and bearings for the same price as a muggy...budget tune done properly works properly ;)
Mine now gives over 14 BHP with a 24 mikuni and tino clubman, with plenty more torque than a 200 (cant remember the figure). These kits are not plug and play to get the best out of them but offer a real 'fun' alternative. Tinkering with this has rekindled my enthusiasm for playing with my Lamby :P
    Users browsing this forum: Semrush [Bot] and 16 guests
