Extended exhaust manifold nuts
red ghost
Main scooter: lambretta gp150
Extended exhaust manifold nuts that can be wired up, can anyone share the overall length and wire hole size?
cheers
Rude De
Main scooter: 69 Gp 200 65 Tv 200
I use Small frame Vespa 7mm coupling nut that holds on the cylinder shroud from the head
vegansydney
Frank if your making some up can you put me down for a set or two. Not looking for favours, I have cash. Thanks! -Benji
Bilko
Main scooter: LI150
I think they vary depending on the exhaust
Bilko's Oily Blog
red ghost
vegansydney wrote:Frank if your making some up can you put me down for a set or two. Not looking for favours, I have cash. Thanks! -Benji
Yes I am and I like cash! :D
Just need length and hole size...
cezeta
mine are 27mm long and with a 1.5 mm hole but the hole can be bigger
red ghost
cezeta wrote:mine are 27mm long and with a 1.5 mm hole but the hole can be bigger
And is there a hole on each flat, so 6 in total per nut?
joee
if your safety wiring them you'll only need 2? obviously on opposite faces ;)
randall ate my dog!!
no one likes us we dont care
red ghost
cezeta
mine just have one hole all the way through
    Users browsing this forum: Google [Bot] and 19 guests
