crank balancing
galpharm
I am building a 225 Mugello with 60mm crank and 1mm packer. new light mugello piston
Also altering porting to 175 exhaust and 150 inlet with 30mm Mikuni and Jl3 exhaust.
I have talked to a local 2stoke motorcycle tuner that can balance cranks but we are unsure of balance percentage to use.
Any ideas
tony
Main scooter: 90ss
try Steve on this website mate.
Professional balancer.
http://www.vibrationfree.co.uk/
galpharm
Thanks Tony.
Talked to them today and they balance dynamically which meens taking in short block which i may do at a later date.
After another conversation with the tuner we have decided for mid range we are going with 65% as this is what he uses for single cylinder motorcross bikes.
So we are going to have a go and see what happens.
RinB
This might help a bit taken from cambridge site
Percentage Of Balance For Pistons
Piston Piston Weight *Approx
Includes all Aux parts Percentage of Balance
Mugello / Imola 186 250g 50.65%
Mugello / Imola 200 292g 44.50%
Mugello / Monza & TS1 336g 38.5%
Mugello / Monza 240 /250 336g 38.50%
Smiffy
tony
Main scooter: 90ss
galpharm wrote:Thanks Tony.
No probs mate. Steve is a top guy. For future ref he will require the whole setup, barrel flywheel motor etc and an idea of what angle the engine runs at.
galpharm
Still confused. Searching the web i have found that 50%-57% is quoted as best for single cylinder.
We are off to Bristol Classic bike show today so i will ask a few questions
galpharm
57% or 65%?
