to give me a bit more range riding back from spain, I'm thinking about adding a bike tank between the seat & legshields.
I want to be able to easily bolt on/off the whole assembly, as i will probably only use it for long trips.
What tanks fit in there well ?
I'm thinking pre-65 trials type tanks...
any pics of lambrettas with tanks there ?
tank in legshields...
- soulsurfer
Doesn't Frank Sanderson do a SS90 style tank for that, or is that a dummy tank? Might be worth a call.
they are a little bigger than a standard ss and they are propper fuel tankssoulsurfer wrote:Doesn't Frank Sanderson do a SS90 style tank for that, or is that a dummy tank? Might be worth a call.
why not use a gs tank that goes in the spare wheel carrier, saves messing up your scooter.
- byron
- Main scooter: Li Special; scarred,but sound
I haven't got a spare wheel carrier...cezeta wrote:why not use a gs tank that goes in the spare wheel carrier, saves messing up your scooter.
and the plan is to have something that bolts on with minimal alterations to the bodywork. i don't mind drilling the odd hole or maybe welding a bracket on, it's only a piece of 45 yr old Italian metal after all
- soulsurfer
Have a look here, looks quite a simple job to fit...byron wrote:the plan is to have something that bolts on with minimal alterations to the bodywork. i don't mind drilling the odd hole or maybe welding a bracket on, it's only a piece of 45 yr old Italian metal after all
http://www.lambrettainnovation.co.uk/vi ... hp?pid=178
- corrado
- Dealer
- Main scooter: Lambretta GP
I think the one on the KTM is it's only fuel tank, as it looks like the seat won't be able to be lifted to access the std lammy tank. Tank would need angling downwards at the rear then it might foul the toolbox door? Frank.......????
Angry Bloke
Upsetter- on the cover of the latest Jetset, has a nice tank which would work on yours
And it looks like a removable one
If I remember correct it is in addition to the tank frank made for this scoot to give it a better range and the option is there to remove but you are right martin Byron will need to have a think regarding the seatcorrado wrote:I think the one on the KTM is it's only fuel tank, as it looks like the seat won't be able to be lifted to access the std lammy tank. Tank would need angling downwards at the rear then it might foul the toolbox door? Frank.......????
