Auto forks in Lammy frame?
Scumdog
Does anyone know of a set of auto forks that will fit a S2 Chrome-ring frame without any fettling? Thinking of going down this route on one of my current projects. Cheers :mrgreen:
FRANK SANDERSON SAID THEY THIS CONVERSION DOESNT PERFORM WELL ON A LAMMY YOU WOULD BE BETTER OFF WITH AN EXTERNAL SHOCK CONVERSION FOR HANDELING THEY DO LOOK TRICK THOUGH THE LAST SET I HELPED ON WERE ZIP 50 ONES WITH A 10 INCH WHEEL AND DISC ON THE LEFT HAND SIDE THE OWNER JIGGED THEM AND I DID THE WELDING
IM SURE YOU HAVE TO WELD SOME STOPS STICKING OUT THE FRAM FOR THE FORKS TO HIT AGAINST AS THE SQUARE EDGE WILL HIT THE MUDGUAERD /LEGGIES FIRST
