New carb required any suggestions ?
flipster
Hi to everyone.Im a complete newbie so please go easey on me !Think its time to replace my crap jettex carb on my bog standard 125 special.Can anyone offer some advice on which carb , price, suppliers etc. CHEERS!
P.N.D.S.C.
Hi.
First thing that occurs to me is that there are other things you can look at before binning the carb and simply sticking a bigger and better one on. You could look at your porting for one thing. There is bound to be a bit of a mismatch if you've simply stuck a larger carb on a standard cylinder, and that will only get worse. It'll be like squeezing the mixture through a funnel.
Talk to Special X about it. He's up your way and I'm sure he'll be happy to help.
i would firstly consider changing the jets to original delly ones......... :lol:
That as well. :lol:
flipster
Thanks for that .Will seek out Special X. But just thought I might as well splash out rather than messing with old jettex as Im not clued up at all with regards jetting etc. In fact all I know is how to put petrol in and curse when she doesnt start ! Thought if i got new carb it would be roughley set up jet wise; old one past its best anyway
P.N.D.S.C.
lammydave
flipster wrote:Thanks for that .Will seek out Special X. But just thought I might as well splash out rather than messing with old jettex as Im not clued up at all with regards jetting etc. In fact all I know is how to put petrol in and curse when she doesnt start ! Thought if i got new carb it would be roughley set up jet wise; old one past its best anyway
there is no guarantee that a new carb will be "roughly set up" as there is a lot to consider when buying one..
engine cc, which exhaust you are using, what type of air filter ... etc....
so, choose carefully ....
as you are running a bog standard 125, i would go with what the others have said and try and get the jetex sorted, and yes, mr special x will be able to guide you as to what jetting you are looking at....
flipster
Thanks everyone for all the advice. I ended up getting another jetex carb which was supplied jetted correctly for me by a very nice bloke called Mike Phoenix RESULT ! She starts and runs a lot better now so HAPPY DAYS ! :D
P.N.D.S.C.
