size of cooper washers on a ScootRS Antidive Disc
kejj
Just need to find out where to get those in Sweden (and what they are called here) Then I can empty it from fluid and refit everything. probably heat the copper washers before fitment.
________________________
http://tv175.wordpress.com/
kejj wrote: Is brake fluid reusable?
Hate to have to rebleed it so at least I hope this will be the only times I have to redo it.
You can use it again provided it is completely uncontaminated and you allow it to stand for a few hours to let the air bubbles to rise to the surface and dispurse. Having said that, how much fluid are you going to need? surely those systems only hold a tiny bit :?
kejj
kejj wrote:I found out that the bolt is 10mm
And the outer dimension is 14mm
there 2 pitch sizes to a M10 BANJO BOLT 1.00MM AND1.25MM SO CHECK WHICH ONE YOU HAVE
kejj
Are we talking thickness here?
kejj
And to show the leakage (this is a new disc brake system that seem like it cant be tightened up enough):
kejj wrote:[quote="shocky"
there 2 pitch sizes to a M10 BANJO BOLT 1.00MM AND1.25MM SO CHECK WHICH ONE YOU HAVE[/quote]
Are we talking thickness here?[/quote]
NO THE GAPS BETWEEN THE THREADS or how course they are
http://en.wikipedia.org/wiki/ISO_metric_screw_thread
id strip it and start again do the bolt up like i said and check the gap thats left then measure the banjo and washers altho its not gonna be much different looking at it or see if you can remove a little from the end of the bolt maybe 1-2mm then see if the bolt goes in a little more
get some fine emery and rub the washers on it and look for high spots do this both sides also check the banjo and the caliper for burrs or raised areas which might let the fluid seep out
dapper
Kejj, looking at your top picture, have you checked that the curved pipe coming from the banjo is not hard against the cut out in the casting, which could be stopping the banjo from sitting square against the cylinder hole, hence the leak. You may have to file the groove/slot a little deeper, so its sits flush.
    Users browsing this forum: Semrush [Bot] and 23 guests
