Strange tick over
yian-ts1
Fitted new devtour pipe, tickover now seems faster when cold, even with choke off, any ideas???
Yian
:cry:
slight air leak ?
that seals as things warm up...?
TS1-200
Might seem a daft question but have you adjusted the tickover screw after fitting the pipe, this could well need adjusting, not the mixture screw, although you may as well set the tickover up again, make sure its hot though
Keep on keepin on
