Series one led rear light
now doing one tonight if all goes well bought this from maplins http://www.maplin.co.uk/module.aspx?Tab ... &U=Strat15
cut into 4 sections of 100mm and wired up
i am using the ali plate (bodge) that was in my rear light but easy enuff to use rubber one or none at all just silicone it on
tested it last night and it worked very well . it has a 39 resistor(??) in the tail light wire and none in the brake light one cos thats what the boy in maplins said do.will be fitting it tonight hopefully
Angry Bloke
I just saw some LEDs on your Flickr site and wondered what you were upto. :?:
I will follow this with interest :D
