BR8ES ?
mickdale
can i use a BR8ES plug - i thought i was supposed to use B8ES?
guy told me the R stands for resister
cheers
mick
oldbiker
R stands for resistor 5000 ohms, needed for electronics using cdi types of circuits if you want to prolong the duration of the spark. a supressor cap uasualy has the resistor fitted.
mickdale
is it the wrong one for a sil electronic set up?
oldbiker
It will work
if you dont have a resistor cap....fit an R plug.
mickdale
thanks for the help guys
ive got a ngk plug cap so probably needed a B8ES but if the BR8ES will work fine i'll use that
cheers
mick
RCA_Racer
5000 ohms NGK resistor plug cap plus 5000 ohms resistor spark plug ????
How will this affect the timing, as I am still convinved that when I used the above set up (I am running the smaller plugs as I have an MMW Cyl Head) , that when strobing this affected the timing by retarding the spark !!!!
Any thoughts on this ?
Italian GP's are just the best.... KTF
