I ordered a standard 200cc Asso piston with three thick rings from but instead I got a same brand piston with two thin rings. The piston is going to be run on a standard engine with 60 mm crank. Are those two ring pistons worth using or should try to get the piston swapped (the shop has no three pistons in stock and is located overseas)?
Thanks!
Thin ring standard Asso pistons
- sean brady scooters
- Dealer
you,ve been supplied with a much better piston assembly than you asked for........
why on earth would you even consider or insist on using the crap one.........?
- Dazza
- Main scooter: S3 LI Rapido 225
Surely that was the point of the question Sean - the chap didn't know which was the better of the two...sean brady scooters wrote:![]()
- Dealer
i was under the impression that he thought the three ring one was better.............and was in fact a bit dissapointed by the two thin ring replacement.........
- rakki
- Main scooter: sx|px|rally×2
Thanks for answers.
I was after three ring piston because I have Finland's greatest collection of thick piston ring sets and my experiences from two ring piston wasn't that good (albeit it wasn't Asso one), but as the general consensus is that the one I got is good, I'll be happy with that.
The piston has been cut couple of mm's from the inlet side, does someone know if it's originally from Rapido or some other piston ported kit?
I had been given to believe that removing 3mm from the inlet side of the piston gave an improvement in mid range ? have I been misled.
Tell me before I get my hack saw out on my new piston Please.
- Andy Pickering
- Main scooter: GP
Think thats the asso piston I got from AF for my stage 4..Sean..?Lazarus wrote:I had been given to believe that removing 3mm from the inlet side of the piston gave an improvement in mid range ? have I been misled.
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 5 guests
