engine out
dirtyhandslopez
I reckon if you've ground that much off the clutch fingers to get them smooth, you are only going to have worse clutch problems down the road as there will be a lot of play in that area.
That's not going anywhere...
iMotors
Won´t be any problem because the clutch discs required a bit more of filing to fit into the clutch basket.
I´ve also received my new liner and piston, and it has 3 rings!!!! my daily work is with diesels so i´ve not a lot of experience with two strokes but i never saw a piston like that before.
Any information about it?
I´ll post a pic as soon as posible.
cheers
iMotors
Here you are...
