urgently needed - who sells 35mm tmx throttle/choke cables?
soullad
Swapping over from dellorto phbh to 35mm TMX so need a new throttle cable and choke cable asap. Its for an S2 if that makes a difference?
Ian
try knowledge on here..... :D
Are you paying attention Ian? Knowledge IS your man :lol:
peter357bikes
Corrado
Knowledge
I have had trouble logging onto this forum today, so sorry if I appeared inattentive.
I can make you a choke cable for a TMX35 for £5 in postage. This is one without an in-line adjuster. In fact, I can make them for most carbs, to order. Black or grey. Mine are designed to work without an elbow, but again, I can accommodate this if you wish.
I'm afraid all the adjustable ones have gone now. I will continue to look for a supplier of adjusters so I can make these a regular item in my catalogue.
Martin
