advice needed for small block tuning
lee1984
hi, im stuck for choice of tuning preformace kit, ie rb200 or rt190 or what else is there,
i have an li 125 casing and varitronic ignition so far,
not sure on what gears to run someone mention'd sx150 gearing.
can someone give me the pro's and con's on the above kits?
and also what crank and gearing please
scooter will be used for town and rally runs so idealy needs to be set up for fast touring.
thanks
lee
"some one mentioned SX 150 gearing"..... :shock:
were they perhaps trying to sell that gearbox............. :lol:
or mentioned it in a "whatever you do, don't use an SX150 box" kind of way
mugello ?
proven kit, with many people using them reliably, and much experience around gearing, pipes, jetting etc.
with a MEC crank
what is fast touring ? what kind of speeds do you want to be travelling at for continuous periods ?
lee1984
byron wrote:or mentioned it in a "whatever you do, don't use an SX150 box" kind of way
mugello ?
with a MEC crank
around 60-70 so i am able to over take on m-way
GP200 or Li150 gearbox, muggello kit, corsa crank, 5 plate clutch, 30mm Delly, JL3 pipe.......off you go.
lee1984
drunkmunkey6969 wrote:GP200 or Li150 gearbox, muggello kit, corsa crank, 5 plate clutch, 30mm Delly, JL3 pipe.......off you go.
corsa crank? were can i find that?
lifes a drag
italian LI 150 gearbox IMOLA 186 , 30mm delly , JL 3 ,,,
Bilko
Main scooter: LI150
Untouched Muggy 186. LI150 Box, 30mm Dellorto, JL3 or PM pipe = flyer!
I'd love to give the RB20 a crack. That's next on the hitlist
Bilko's Oily Blog
eibargum
Lee, ive just helped a mate put one of the new muggy 186,s together, and IMO it would have benifited him to have some extra meat welded on the transfers on the caseing, both for some extra gaskit face and/or to open up the transfers some more, while your thinking about which kit to go for if i were you i,d get the caseing welded, my choice would be the RB20, seems good value ;) .
RB20 , race crank tigd and balanced , Li150 box , BGM stator , indian flywheel , 5 plate clutch , 30mm flatslide dellorto , Franspeed Pipe , vroooooooommmmmmmmmm so far :lol: :lol:
    Users browsing this forum: No registered users and 52 guests
