Whitewall weathermans
marburys
Hello was going to fit above to series 2. But been told they only last 1000 miles as of being soft compound, any help on this subject
a.lo
oh dear, ive just fitted them, changed from Conti w/w that i would get about 2/2500 miles out of. only done about 250 on the new ones so will keep an eye on them and keep you posted
You should get at least 2k out of the rear tyre, mine's about that now and is pretty well on the limit. The front has hardly worn at all. Brilliant tyres though, you don't get wet weather grip like that without having a soft compouind.
Monty
Agreed 2.5 to 3K on the rear still going when it went, on the front, sticks to the road is the clue? worth it in my opinion
timdig
3k on my weatherman rear tyre and plenty of drag starts, not whitewalls tho. if they wear they r working in my opinion. front still good for another 3k
Ian Hepworth
coaster wrote:Brilliant tyres though, you don't get wet weather grip like that without having a soft compouind.
That's it in an nutshell - you can't have it both ways.
marburys
Thanks for your advice, we go with the above as look better grip wise than conti s
carlosfandangles
Only thing between you and road so 3k sounds plenty good enough for me bearing in mind a rear tyre only the cost of a quiet night out.
