Pinking at high speed with barely open throttle
J1MS
I think if the material is taken from ther bottom of the slide and not the cut away then it will richen up the carb first 1/4 throttle, as the cut away in relation to the slide position should be lower.
Not sure how you would go about this if its a Mikuni, as I dont run them on mine.
I think Jason might have a good point with the slide choice.
jason frost
sean brady scooters wrote:yes ,see above post jase .........
i did not understand what you meant at first..............
must be my Sheffield accent :D
