The casings have been machined for the cylinder to fit, and machined to fit a 54mm full circle crank
Sill got to remove lots of the ally welding as I had loads of weld put on as I wasnt sure what Id need, this is only the second smallie engine that I ve built so Im learning as I go along
Next job is to fit the crank to check that the measurements for the packer height were correct
Lots more to do so I'll stick a few pics up as and when
