I'm looking for a couple of brackets to be made up for my foot pegs.
I have two SLJ clamps coming from the engine mounts and I have two motorcycle rear sets. I just need two plates made to joing the two!
If someone could help, I'd really appreciate it.
Metal Guru Required: Part 3
- sean brady scooters
- Dealer
- Contact:
either put some pics up,showing whats required or just get yourself around your local engineering shops......there must be someone local to you that could make these easily.
- wack 63
- registered user
- Main scooter: '71 GP TS1
- Contact:
What happens if you take off the peg and turn the hangers over so the larger hole could fit over the engine bar? then you would only need one plate making per side. Or do you want to see the logo and use the master cylinder mount?
