imola 186
sjc
need some jetting help,,just rebuilt my mates engine and need some jetting details,, using a 28mm dellorto open faced,, scoot rs exhaust,,italian gp 125/ 200 gearbox 18 x 47,, castrol tts power 1 oil at 3% many thanks steve....
sjc
can any-one help please :cry:
heres one of ours
imola 186,scootrs pipe,28mm delly
main jet 132
pilot......52
needle ...x7 on 2nd clip
atomiser...AV266
needle/tap jet..250
choke ....70
slide ...40
air screw 1 turn out
hope this helps you mate.
sjc
thanks sean,,
sjc
sean,,have you got any more jetting details for the imola kit,,used your jetting as suggested it runs rich right through the range,,any ideas would be great..all the best steve v.s.s.c.
soullad
sjc wrote:sean,,have you got any more jetting details for the imola kit,,used your jetting as suggested it runs rich right through the range,,any ideas would be great..all the best steve v.s.s.c.
Check choke not sticking on first before you splash the cash :?:
sjc
the chokes working perfect thanks though..steve v.s.s.c.
sjc
sorry soullad,,you was right,the choke wasnt sitting all the way down in its recess,,,cheers sean runnin spot on now,,,thanks for all the help..steve..virgin soldiers s.c.
    Users browsing this forum: Google [Bot] and 9 guests
