suzuki 205 piston kit
C*NTSPEED
anyone know of such a thing or a piston thats a straight swop for it?
GEMINI S.C.
BLACK WIDDA'S S.C.
soullad
sounds interesting......obviously theres the Suzi 225 kit, using the TS250 piston (note it needs a crank suitable for an 18mm small end bearing or a pin sleeve) and the Honda 205 using the MTX piston..
I think the largest oversize of the TS185 pistons is 66mm ....could this with a 60mm crank be what you are referring too?
soullad wrote:sounds interesting......obviously theres the Suzi 225 kit, using the TS250 piston (note it needs a crank suitable for an 18mm small end bearing or a pin sleeve) and the Honda 205 using the MTX piston..
no ythe late 70,s early 80.s rm 250 piston was 67mm i think there only single ring gp 4 race scooters mine inc used this piston
dont think they were that suatable for the road due to the one ring
oversize one here
http://cgi.ebay.co.uk/SUZUKI-RM250-RM-2 ... _600wt_939
they used to be cheap and worth using if you didnt mind the maching of the cylinder MB PISTONS do away with the need to use these old ones really but if you can get maching done for nowt and need to have a crank rebuilt why not put a 116/18 rod in there isnt gonna cost much more
C*NTSPEED
all i know is mi mates lamby is a suzuki 205 and the piston is rather worse for wear so im trying to find a replacement for it
GEMINI S.C.
BLACK WIDDA'S S.C.
C*NTSPEED
i just found this?
http://www.lambrettaspares.com/sparepar ... ls362.html
so soon as i know the size i require i take it its a straight swop?
GEMINI S.C.
BLACK WIDDA'S S.C.
it depends what con rod he has some people used the tv rod and less machining of the clinder som used a standard rod and machines alot from the top
C*NTSPEED
bugger all i thought i had to do was measure the bore and get one to suit
GEMINI S.C.
BLACK WIDDA'S S.C.
measure the piston overall lenght and from the crown top to the center of the gudgeon pin the top of the piston should have something on like STD or.25 or .5
C*NTSPEED
you reckon its just easier to take the piston itself to broadys to get a match?
GEMINI S.C.
BLACK WIDDA'S S.C.
MrG68
Chalky at REPLAY scooters has done a few of these conversion may be worth giving him a ring!
    Users browsing this forum: Ahrefs [Bot] and 17 guests
