headcowling, thread stripped
joda
the headcowling on my jet came loose, so i fitted longer bolts top and bottom to try and benifit from all the avalable thread [note this is the the small cowl bolts, not the one m8 that fits into the head stud]
but this hasnt worked and it rattles all the time,
whats the tried and tested meathod of repair? chemical metal/jb weld? cable ties have also mentioned. i was thinking 2 large self tapping screws, but i fear this cowl may have to be off and on more times than a whores nickers at the start of this season while i play with exhausts and feel a self tapper will just chew the case up even worse if its constantly removed and replaced
thanks
you could use longer bolts and then nuts on the other side under the flywheel cover.. :D
Dimitrios_231
:idea:
Bolt head from the flywheel side,
nut from the outside?
Dimitrios_231
sean brady scooters wrote:you could use longer bolts and then nuts on the other side under the flywheel cover.. :D
Genius mind :lol:
Knowledge
Dimitrios_231 wrote::idea: Bolt head from the flywheel side, nut from the outside?
I always do this, with M5 bolts from the inside and NYLOC nuts from the outside. That way, the nuts will not rattle loose.
Martin
joda
thats si simple it may just work :D
thanks very much, dont know why i never though if that!
dapper
Helicoil the holes and then use Loctite threadlock.
jason frost
do it M6 or have a timesert fitted.
hydra
new Mag Flange £20, drilling, tapping, timesert, Helicoil or weld, all are eiher more expensive and may weaken the fingers where the holes are, especially the bottom one. Just buy another mag flange and change your seals while you are at it ;)
J1MS
I fit a second long cylinderhead nut to mine, diagonally from the original. This giving two 8mm threaded 13mm bolts as mounting points (once you drill a second hole in the cowling).
Even if the little bolts come loose the cowling dosnt.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 23 guests
