Legshield Toolboxes...
6LDA 28B wrote:I keep thinking leg shield toolbox as i have a long range diablo tank with a small toolbox but not sure if it would look right on my series 3, what is the best sort to look out for (money no object Cezeta is my sponsor) Image
and then where to put the spare wheel
The PX style look ok on the GP but on a Series 3 I prefer this http://scootrs.com/moreinfo.cfm?Product_ID=132
I have the same tank and a Vespa GS toolbox trimmed to fit, welding in is optional :shock:
micky1
now that looks tidy!
Bilko
Main scooter: LI150
Really tidy.
Bilko's Oily Blog
cezeta
you need to concider that it will look crap freshly painted against your old paint, then you need to ask yourself what on earth you are going to put in it and thirdly im a tight assed b@5t@rd so you ll get a s**t one for the £7 im prepared to pay.
in fact i have one, a serveta series 3 one you can have but as you say where is the spare wheel going?
sugarlump has bought a plasma cutter so im off over to his to cut up his dads car and build a tool box into the inside legshield spare wheel carrier. it will take another ten years to get round to painting it but hey :?
minotaur
this is what i chose http://scootrs.com/moreinfo.cfm?Product_ID=70, it does look like this fitted with enough room for a couple of dials on the top, like the look of soulsurfers but it must of took 4 eva to weld, smooth and fill, must have been worth it tho'
gaz_powell
i`ve got a fibre glass nannucci copy one on an sx which was a pig it ended up very shallow after fitting it
i`ve got a vespa px one - again a pig again ended up shallow
and finally a scootrs rally style on on my gp and it fit perfect with no work at all with plenty of space
probably going top change the sx to scootrs one
Train Driver
Cezeta wrote
you need to consider that it will look crap freshly painted against your old paint, then you need to ask yourself what on earth you are going to put in it and thirdly I'm a tight arsed b@5t@rd so you ll get a s**t one for the £7 im prepared to pay.
sugarlump has bought a plasma cutter so I'm off over to his to cut up his dads car and build a tool box into the inside leg shield spare wheel carrier.it will take another ten years to get round to painting it but hey :?[/quote]
somewhere to put 1000 miles worth of two stroke oil, i will look at what you end up with after you have cut up a poor pensioners mobility car
cezeta
1000 miles of 2 stroke oil, how about this but with a tap at the bottom
damdam wrote:Is there anyone that use a legshield toolbox (even modified) as spare wheel holder? Or is it impossible due to the limited space for legs?
i know someone who does that modification if you want it just PM me
cezeta
got any pics shocky?
    Users browsing this forum: No registered users and 68 guests
