Cam Lam breath sweet filter
cezeta
GlosRob wrote:Sorry I am confused I want a filter for my TS1 running a TMX 35 mm with full panel work where do I buy ?
cambridge lambretta, they only sell one called a "breath sweet" take a look
GlosRob
Having now spent some time reading the whole thread I am not so confused :oops: So is anyone out there using this filter on a TMX 35mm housed in a GP.
cezeta
ive seen them used on an sx200 which should be similar. i think you may need an mbd or jimmers short manifold though.
GP Kevo
cezeta wrote:i just measured mine, its 55mm id and the tmx 35 is about 60mm but it does go on fine. you would not want it loose. you have to fit it like fitting a tyre then undo the jubilee clip and wrap it round n do it up.....simples
Ok, cheers, cezeta, I'll try that when it warms up outside which means next week at the earliest. It's -3 C today with -7 C windchill
This is for my GP200 (DL) with MB RaceTour ported TS1 230 with MB manifold and V-Force reeds running Mikuni 35 TMX.
cezeta
same set up as mine but i have a 71mm piston and im convinced it runs better with the filter possibly because the air is funneled into the carb rather than turbulent against the panel or maybe because my subconscious just wants it to run better, i can never tell :?
but its nice and clean under the panels and i dont s**t myself as i go over freshly gritted roads so thats what i was after.
cezeta wrote:i dont s**t myself as i go over freshly gritted roads so thats what i was after.
Ditto... :D
GP Kevo
cezeta wrote:same set up as mine but i have a 71mm piston and im convinced it runs better with the filter possibly because the air is funneled into the carb rather than turbulent against the panel or maybe because my subconscious just wants it to run better, i can never tell :?
Same here, 71mm x 58 mm TS1 RaceTour porting, and I wanna keep the "loose chippings" outta the engine.
The sun is out today but there's still ice on the roads and we're going back down to -7 by Friday. :x
GlosRob
So kevo are you running one or just wanting too ?
GP Kevo
Currently I'm running the MB Flat Ram Air filter that I've run for two years. I have a Breath Sweet filter that I may try putting on tomorrow if it gets above 0º C outside.
    Users browsing this forum: No registered users and 66 guests
