gearbox advice please
ratty
Main scooter: LI ser3 125 {TS1 230} 1963
have just swaped my crap serveta 150 box for a sil gp200. will i need to change my clutch spider or will i be able to re use the one i have, and do i need to swap anything else while im at it. thanks :?:
how much!!!
minotaur
all stays the same, just shim the new box correctly
ratty
cheers, my mate is building it for me, not done a gear box before! but he was worried the preasure plate/flange would not mach up,have read that i need to swap the needle bearing that i have, for the brass bush type as the sill christmas tree wont run well in it?
how much!!!
TS1-200
I think your getting confused with the needle roller bearing for the clutch bell, the GP clutch bell uses a solid bearing whereas the SX/LI clutch bell uses needle rollers, the gear cluster/Xmas tree, GP or SX/LI always runs in a needle roller bearing
Keep on keepin on
ratty
thanks mate,thats why i aint doing it!!!!!, thats what he wanted to know,cheers.
how much!!!
    Users browsing this forum: No registered users and 21 guests
