Cam Lam breath sweet filter
I would say the first picture as that whats I have and cezeta and lozmondo said he had been looking for that one when I posted that picture on another thread..
ArmandTanzarian
The German ones look quite interesting but I'm not sure that they'd have enough surface area to get enough air through.
lozmondo
Yes the first one. It came from Scooter Centre in Cologne (2 day delivery!!!)..10% LCGB discount as well apparantly which I didn't know about :cry:
Have upjetted to be safe, but will keep an eye on the plug colour. I know corrado is getting some in to fit the 24mm at some point
cezeta
its the top one ive used on a tm24 and a tmx35. perfect on both.
i dont think the german one will do the job unless you put a hole in the panel
GP Kevo
Are there two different sizes of rubber bellows for the CamLam filter? Because if it fits a TM 24 then it won't fit a TMX 35 with bellmouth outside diameter (O.D.) of 62 mm.
I tried fitting mine (the Camb Lamb filter) and the rubber bellows will not fit over the TMX 35 bellmouth. The O.D. of the rubber bellows on the Camb Lamb filter is 55 mm. Do they have different diameter rubber bellows for their filter?
cezeta
there are two sizes, i think scooter centre sell both but camlam do not for some reason. the bigger one is a tignt fit on a tmx 35, i dipped mine in hot water then fitted it on the tmx 35.
before the smaller one came out i had a bell mouth for a 25mm delly machined down to be a push fit onto the tm24 then the rubber goes on to that. this methed should give better performance in theory :? who knows.
GP Kevo
I'll try using a heat gun to heat up the rubber bellows, but it has to strech 7 mm. :shock:
Do you have a link to the German shop page with the larger rubber bellows?
Thank you :)
GP Kevo wrote: Do you have a link to the German shop page with the larger rubber bellows?
Thank you :)
http://www.lambretta-teile.de/suche.php ... 4mee42e3fs
cezeta
i just measured mine, its 55mm id and the tmx 35 is about 60mm but it does go on fine. you would not want it loose. you have to fit it like fitting a tyre then undo the jubilee clip and wrap it round n do it up.....simples
GlosRob
Sorry I am confused I want a filter for my TS1 running a TMX 35 mm with full panel work where do I buy ?
