How much type of Escorts front shockers?
ArKaTxU
Hi.
There are two types of Escorts shockers?
Wich are the best?
Soulpunk
the 2nd ones , fatter type is very good (technically).
they are very good dampers.
the first ones i don´t know.
the first damper is thinner, but its proportions (mounting-lugs/silentblocks)
look worse.
so theres no option: choose the 2nd pair
for looks on a resto choose sebac original type anyway (technically not good as escorts).
ArKaTxU
Soulpunk wrote:the 2nd ones , fatter type is very good (technically).
look worse.
OK, thanks!
You can cut the larger shroud off the fat ones and turn them upside down for a nice sportier look too ;-)
ArKaTxU
soulsurfer wrote:You can cut the larger shroud off the fat ones and turn them upside down for a nice sportier look too ;-)
Have you got a picture to see?
Thanks.
Thanks.
http://www.lambrettainnovation.co.uk/vi ... pic_id=901
I did it a while back, easy to do and they look good ;)
ArKaTxU
Thanks.
Looks good!
