air filter size?
i want to stick a k&n filter on my phbh but forgot to measure it ,does anyone know?
cezeta
you want to concider the breath sweet one.
i know what one i can use i really need size of clamping area
GP Kevo
Is there a larger Breath Sweet filter? One with a slighly larger rubber bellows mounting face to the carb? Like one to fit the Mikuni TMX-35 whose bellmouth diameter is 62 mm?
rog60
Main scooter: Indian GP200
I'm using the standard rubber hose (22mm size) and a short piece of plastic waste pipe over the threaded inlet on a 28PHBH to give a better seal (can't remember the size of pipe tho)
skidmark
GP Kevo wrote:Is there a larger Breath Sweet filter? One with a slighly larger rubber bellows mounting face to the carb? Like one to fit the Mikuni TMX-35 whose bellmouth diameter is 62 mm?
Scooter Centre Koln do a 60mm one that fits the TMX 35 I have one fitted to my Rapido 250 and seems to work well.
GP Kevo
Thanks for that, skidmark. I have the CamLam breath sweet filter which I have now stretched over the carb bellmouth but I'll check out the SCK one as it will be much less of a stretch.
Here's a vid of my bike with the filter mounted. I now have a jubilee clip securing the rubber bellows to the carb.
    Users browsing this forum: No registered users and 55 guests
