No brake light
rog60
Main scooter: Indian GP200
byron wrote:^yep
and also use your multimeter to test the switch
remembering that there should be continuity when the pin is out
And make sure you've got a good earth to frame from reflector.................
Bilko
Main scooter: LI150
Went out the morning to have another look and for whatever reason, the back light and brake light work. A bit frustrating without knowing the cause. I'll keep a close eye on it.
Thanks for all the help. :)
Bilko's Oily Blog
Fireman Ash
Check yer bulb as they can be faulty and intermittant, happened to me at the MOT station. I always use a multi meter now as previously suggested..
