Cam Lam breath sweet filter
yellow peril
Has anyone fitted one of these to a reedvalve engine TS1/Monza etc... just how much clearance is there and does it restrict the flow etc...
Just checking before i take the hole saw to the panel!
GP Kevo
Soon, if it fits over my 35 TMX bellmouth. As soon as the weather warms up I'll be working on the bike, maybe a couple more weeks until the snow melts.
There is also another filter that fits under the panels on the ScooterCenter website.
leebeduff
That Scooter centre one looks short,would it still do the job?
I'm sure it probably explains how it works , knew I should have
paid attention in German class at school!
In English...
28-43mm or 46-62mm Available in red or black.
Sound the same as MB 46-62mm
cezeta
i have one on my ts1, breaths well. i have a diablo tank so i have mine horisontal. i like em.
i have the same on a 24mm mikuni on my jet200 too
GlosRob
Do you not have to change the reed block to accomodate the Cam Lam Filter ?
cezeta
GlosRob wrote:Do you not have to change the reed block to accomodate the Cam Lam Filter ?
mine is an mbd manifold on a series 1 so its no issue, i have not had a chance to try it on a series 3 but the mbd and jimmers manifolds seem the same in protrusion from the barrel. i believe mbd will be bringing out a new manifold which is shorter still. i know of some series 3 s running the jimmers manifold with no issue.
the only thing you need to do with the breath sweet is get a steel ring inside the fiter/rubber junction otherwise the jubilee clips pinch and crincle the rubber as there is nothing to compress against.
lozmondo
Just tried one of these on a 24mm Mikuni fitted to a fettled SR 185 kit...the difference compared to a standard bellow with a Ram air fitted is staggering, a vast improvement. :shock:
lozmondo wrote:Just tried one of these on a 24mm Mikuni fitted to a fettled SR 185 kit...the difference compared to a standard bellow with a Ram air fitted is staggering, a vast improvement. :shock:
Any jetting changes done..?
ArmandTanzarian
When you say "one of these" do you mean the cam lam one mentioned in the thread title
or the short one on the german site
    Users browsing this forum: Baidu [Spider] and 4 guests
