LI Kickstartshaft in a GP200 Engine
challenger
I need a kickstart shaft for a GP200 Engine Im rebuilding.
Given that Ive already got a few LI Kickstart Shafts, will they fit and work in a GP motor, do I need to change any parts...like the plunger or anything.
Thanks ;)
challenger wrote:I need a kickstart shaft for a GP200 Engine Im rebuilding.
Thanks ;)
Li shafts are allegedly weaker than the gP ones . id fit a gp shaft if you have the choice
Scooterso
The Li shaft should fit although you might need to shim out a bit on the outside (MB make various size shims for this - we stock them in USA). Its going the other way that needs modification (Li using GP shaft). They are weaker though!
challenger
Thanks ;)
I think Ill buy a new one..
