kick 'non' start
minotaur
.... had a bit of a scraping noise in chaincase which disappears when clutch is pulled. tried to kick yesterday and kick start only turns engine every 4th kick, thought clutch might be slightly engaged so un hooked cable and still the same, this is a new build so could it be plunger? looks like another job for next w'end :(
soullad
minotaur wrote:.... had a bit of a scraping noise in chaincase which disappears when clutch is pulled. tried to kick yesterday and kick start only turns engine every 4th kick, thought clutch might be slightly engaged so un hooked cable and still the same, this is a new build so could it be plunger? looks like another job for next w'end :(
just sounds like the inner kickstart shoulder rubbing on yer top clutch steel...........Just either grind a little off the shaft or fit a thinner top plate.
minotaur
hope it's just that , kicked over fine for a couple of weeks, thanks
