help starting it up
leehuggy72
dapper wrote:Lee two other things to check. What flywheel do you have fitted? I ask because there have been problems with the BGM stator lining up with the trigger magnets inside certain types flywheel. The other thing is, is the carb an OKO PWK copy, or a true Keihin PWK? If its a copy, then sometimes you have to strip the carb and remove the float. At 90 degrees to the float pin there is a hole that allows fuel from the float valve down into the float bowl. That hole needs to be reamed out with a 1mm drill. Secondly, when you look down into your carb from above where the slide fits, you will see the main jet. Just behind it towards the engine side of carb is a tiny hole, which is the pilot. This can get gummed up or blocked with glue/gasket which holds the two halves of the carb together. You can take a 1/2mm drill bit held with long nosed pliers and check that it will go through that hole clearly (take pilot jet out first). After you've checked, place carb on bench with a bright light shining through from below. Block the main jet with a finger, and by moving the light up and down you should get some light through the small pilot drilling. Also blow through with an air duster.
flywheels an AF one
its a oko , but has come from another scooter rider hex main etc etc
ratty
Main scooter: LI ser3 125 {TS1 230} 1963
reg yellow,brown,earth in that order left to right......cdi green,green,red,white, from bottom to top,
how much!!!
leehuggy72
ratty
yellow brown earth thats what i've got
but my reg is a 12v dc 5 pin (green,green,brown+,c,earth)
will this matter
ratty
wont matter mate yellow in first hole brown in second and put your black earth wire in the 4th hole,try taking the green ignition wire off your cdi if the scoot still wont start.
how much!!!
leehuggy72
she's firing up then dying straight away
choke on and kick her off she wants to start then dies..
if at any time i try with a little throttle it doesn't want to know
tried turning choke off and leaving throttle and she wants to start again
keihin carb?????????
carbs been stripped half a dozen times
electrics are fine to what it should be
ratty
might be worth trying another carb off a running scoot mate to discount that side of things,
how much!!!
minotaur
check the choke mechanism is working properly, had a hard time starting mine with a 30mm oko pwk then realised when i pulled the choke the outer was moving but not the inner, fixed it and now starts 2nd kick....
dapper
Le you can get a lots of spitback on these carbs. You can drill a 1mm hole in the bottom of the carb hose to drain off excess spitback. Have you tried her without the filter?
leehuggy72
UPDATE
My bloody legs killing me..... :lol:
Electrics are fine
turned my attention to the carb, cleaned it again jetted it up to roughly another persons setup like mine
kicked her off and WOW she came to life..... what a freaking sound
then she dies...
messed around with the air screw and idle screw.. managed to keep her idling but doesn't like it.
it only runs with choke out even when hot...
doesn't entertain the throttle at all...
pilot 32
needle is a bgm pw28 mid clip (don't know yet what this equates to regarding jjh gjh needles)
main is 120 its the highest i have until i can get some more
ratty
nice one,well at least your going in the right direction lee.
how much!!!
