power problem
roadrunnerian
Hi,
here is some details as requested by sean,it is a stage 4 barrell and cylinder head with a asso piston with 3mm cut off, i am running a 28mm dellorto phbh with a 122 mains jet amd 42mm
fresco exhaust.it has a race crank and uprated springs on the clutch.thanks for your replies so far. :?
Dazza
Have you checked the flow rate? I had similar with a 30mm phbh , it would run perfect until I caned it in top gear, it would backfire and miss until I eased off the throttle to give the carb chance to fill up again, i changed the tap a few times until I found a true fast flow one (camlam) incidently.
roadrunnerian wrote:Hi,
i was actually hoping for a far more comprehensive reply than that matey..in order to give us some clues and help us help you....... :D
for eg..
Tap jet size....?
main jet...........122
pilot jet...............?
Atomiser/diffuser......?
Slide..................?
needle and setting........?
and is your carb fitted with a filter or does it run open with or without hole in panel..........?
Lazarus
sean brady scooters wrote:
roadrunnerian wrote: :?
sorry to butt in Sean but as im paying attention to this post can you explain about the "Tap jet size "
ie: do you mean standard or fast flow fuel tap or something else ?
for eg..
Tap jet size....?
roadrunnerian
hi i think best thing is to nip over to you with the scoot because i am just getting back into it after a thirty year break and a lot of this stuff gone straight over my head.it has a rayspeed quickflow fuel tap and has the rubber air filter bellows with a fram sponge filter on rest of the stuff i am sorry unable to help. thanks for all of your help everybody
soosh
Ive had my Saxelby stage 4 with a phbh28 with PM set up as this on the dyno:-
115 main AV264 atom with X13 needle on 2nd clip.Think its 50 slide,cant remember the pilot but think its 55.Its got a 300 float needle valve.On the main,you may wanna start at 120 but i found that too rich and 118 was advised if on a long run and flatout but have always used the 115 and its spot on.Timing is static at 19 degrees.Hope this helps mate.
roadrunnerian
thanks soosh may try your settings
    Users browsing this forum: Google [Bot] and 18 guests
