Waxoyl..................
dapper
anyone ever bothered with injecting it through the drain holes in the bottom of the frame when doing a full resto? Is it worthwhile?
bristolmod
what drain holes?
Scootering since 1968.
dapper
bristolmod wrote:what drain holes?
On my Injun resto there are two 1/4" drain holes in the bottom of the main spine. Maybe it was sumfink the Injuns did cause of the monsoons :D
Stampede
Main scooter: SX200
there´s usually one drain hole on each italian frame amounting to the rear brake pedal...
I´ve put a similar wax into my frame on the last resto, no problems and i think it helps! ;-)
dapper
Mine has the one adjacent to the rear brake pivot mount and another 1" behind the main engine mount.
jason frost
They should be cleaned out after painting, they let any water out, putting waxoyl in may block them up and just move the water up the tube. Another way is to move to some where hotter :baddevil:
    Users browsing this forum: No registered users and 21 guests
