would be gratefull thanks
power problem
roadrunnerian
i have noticed with my stage 4 gp200 which has had 3mm cut off sometimes when you open it up it goes great but when i was overtaking some cars i had to shut off then open up it won't go give it 20 seconds and it goes. could the cut off the piston be the trouble any advice
- sean brady scooters
- Dealer
your trouble is probably down to carb set up.....did you have it dyno,d after the tuning mods..?
roadrunnerian
thanks for the quick replies no i have not had it dyno,d because the person who built the engine said it was all set up right.how much do you charge per hour? i live near chorley its not far
- Stampede
- Main scooter: SX200
would be the blowback, i think. perhaps go for a LTH manifold to sort it!
Longer inlet timing (shorter piston
) doesn´t make this problem better....
Which carb do you use? A big one, bigger than 25mm?
roadrunnerian
i have a 28mm carb on the scoot m8
- Dealer
your carb settings,irrispective of what carb or size it is will need setting up for the new stage 4 tune.....
your tuner should have advised you in that respect........
typically you may find the need for a smaller pilot jet,and maybe diffuser and needle changes....etc
perhaps post up your carb /engine details and then maybe we can give you some pointers
Is it a PWK type carb by any chance ??
Best Regards
- Information
Who is online
