is this the ideal gauge, egt, cht and rev counter with alarm
cezeta
seems to have included everything into one gauge with programable alarms. looks good to me...can anyomnre think of any downsides before i buy one?
http://www.occpowersports.com/eshopprod ... METER_.htm
micky1
looks good to me,where are the extra sensors listed? would be good to have all the bases covered, could even do a bit of a group buy???
cezeta
here is a uk supplier, i have bought from them before. maybe a phone call is needed
http://www.digital-speedos.co.uk/
does it do EGT AND CHT
cezeta
shocky wrote:does it do EGT AND CHT
Highly visible, backlit digital display shows RPM and dual temperatures
Large digital rpm readout and REV bar-graph make it easy to read rpm at high speeds; REV indicator is programmable to 10000, 15000 or 20000 rpm
Dual temp meters have programmable high-temp warning lights; 32-482°F range (0-250°C)
Records max rpm and temp
Also features volt meter, time, programmable shift light and optional air/fuel ratio meter
Includes water temperature sensor; EGT sensors, oil temperature sensors and cylinder head temperature sensors available separately
Measures 85.7mm W x 30.5mm H x 19mm D
it looks like it, all the sensors are thermistors so there should be no reason why not?
trev t
just got one of these mb developments,, very good
Does it work with single stroke engines
Looking at the instructions it seems it does a/f ratio but not EGT. No sensor listed and the temp guage only reads up to 250degC. Nice guage all the same.
cezeta
i think you are right :roll: :roll:
however they do this one
cezeta
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
