SLJ Rear mounting bracket
bazman
Hi have fitted one of these but unsure if it's supposed to have a lot of play in rear muffler? See attached video , what do you guys think? Cheers Baz.
http://www.youtube.com/watch?v=uL8jeGnEy4I
lockman69
bazman wrote:Hi have fitted one of these but unsure if it's supposed to have a lot of play in rear muffler? See attached video , what do you guys think? Cheers Baz.
Bazman, I have just fitted mine, (JL3) I have a bit of play also, maybe not as much as you, there is a fair bit of play on the rubber cotton reel.
bazman
Cheers , yeah meant to say there's a lot play in the heavy duty rubber cotton reel!
hydra
MBD Devtour bracket on a JL3 End
Bufficus
hydra wrote:Image
Similar to mine. But I use a Devtour bracket and end can on my TS1/JL4
Bufficus
Is the SLJ bracket is the same as the brackets supplied with JL/Franspeed pipes? If so, move the bracket in a clockwise direction onto the next set of studs and the bobbin should line up with the hole in the end can support.
The Franspeed race pipe on my RB is fitted like this and works a treat. No need for an additional tie bar. (picture to follow if required)
If the SLJ bracket is different, apologies for butting in.
bazman
Hi , no it's not the same unfortunately, similar to franspeed , did try all the mounting arrangements but no joy. Will have another look 2moz, like the idea of the mb devtour bracket though 8-)
Does the devtour tailcan fit the jl's ok?
Bufficus
Bit tight, but goes in. Better looking and sounding than the JL IMO.
hydra
another view of MBD Devtour bracket on JL3
bazman
hydra wrote:Image
That looks a bit more substanial :)
Do you have too get extended chaincase studs for the mounting bracket?
Also do you know how much and can they be purchased seperately?
Thanks Baz.
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
