SIL200, Ancilotti Clubman, Mikuni TM24 - jetting?
adriang
Can anybody give an idea on carb set up for a SIL stage 4 200, TM24 (planning on running through the airbox, not sure if I'll put anything in it) and a clubman?
Been trawling the net, and quite a range of main jets and needles?
Just trying to figure out a decent starting point!!
PaulO
185 main
15 Pilot
4dh7 needle (2nd from top clip position)
1.5 turn out on air screw.
Not through the airbox though,remote ram air on origional elbow
42mm ancillotti (sito)
done 2,000 + miles
Hope this helps.
Honeymonster
If the 4DH7 needle doesn't work, mine cut dead at every attempt to run it, try a 5N13-2 (-2 referes to the 2nd clip position) All else as suggested but final test the main with plug chops.
Ian
lozmondo
As Honey monster but 190 main on an SR185.( thoght that being probably over cautious as running in) this after Dyno session yesterday which showed although 180 main was just ok it had a tendancy to lean off a little.
adriang
Thanks all, a useful starting point!
