electrix...?
firekdp
fajes wrote:it's alive!
I connected one of the double green to the CDI and got a nice spark, but the killswitch is not working... should I also connect the other green one (the one with the crappy red connector on it in the pic) to the CDI for the killswitch?
Yes, but if you use that one make sure that the other 2 greens are connected together. Or try the other one of the pair as this one should go direct to the kill switch.
peter357bikes wrote:What is the function of the purple wire from the switch housing as I have bought a new loom (with front brake addition, pink and another brown).
Green, brown and black run continuous with pink and brown spliced in for front and rear brakes )
This is for my S2 which came with a rather messy 12v conversion).
There is no purple in the loom but there is one from the switch.
At the headset I have a double brown, a green and the black. Can I connect the purple into the brown at the headset?..I thought I had this sussed till I found the purple.DOHHH
Yes, connect the purple to the browns as this is the feed into the switch for the pilot lights.
fajes
next time I'm buying one of those upgraded-simplified wiring looms!!
wine for my men, we ride at dawn!
