sealing joints on a JL3 tips, please?
goffy
any advice on sealing the joints on a JL3 to stop any blowing, what do you guys use? cheers!
bathroom silicone sealant
goffy
thanks shocky,
so do you put the sealant around the outer part of the 2 joints, or put some sealant on so it sits inside when the 2 joints are put together, if you know what i mean?
Chris CSPE
So it sits inside, clean the joint with brake/clutch cleaner first .
Eibar
Main scooter: Eibar TS1 1966
We have always used a length of mountain bike inner tube, perfect fit and doesn;t burn. simply rolls on and off - TOP TIP
potato
soullad
Eibar wrote:We have always used a length of mountain bike inner tube, perfect fit and doesn;t burn. simply rolls on and off - TOP TIP
Any pics? I assume you mean the tailcan joint .........what about the exhaust slip joint?
Eibar
Yeah tailcan joint simply rolls, always done it, been no probs at all, 3"long
potato
    Users browsing this forum: Ahrefs [Bot], Majestic-12 [Bot], Semrush [Bot] and 7 guests
