Podtronic ignition/rectifier
AUSSIE
Where can you buy a podtronic stator/ recectifier set up?
Is this the type that spanish serveta used to use? Do you still have a regulated 12volt ac supply or is everything run through the battery?
Google will find a supplier.
Don't know about Spanish stuff.
It's DC all the way and requires a wire disconnecting from the stator and taking up to the Podronics box.
Hope this helps
AUSSIE
cheers for the help
