Offset cones for reed valve
yellow peril
Hi All, when fitting do you position the offset to either lower the engine clear of the frame or forward, both seem logical but which is the correct/preferred method?
Cheers in advance
camel
lower, to clear the manifold away from the frame especially if your using a packing plate on the reed valve
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
