electronic ignition probs
gillykendal1
just fitted new pick up box on a af indian stator on my a mates bike (lambretta) as old one knackerd we fitted a vespa one .correct reading on meter but when we turn the flywheel (af lightened) we hear clicking noises 5 in one complete revelution of flywheel its not catching anywhere as we have marked anything that can catch and its ok. its like a pulse sort of noise and seems to happen as magnets pass the pick up box the bike starts 1st kick and seems to run ok i just wonderd if anyone has come across this before . thanks nigel
J1MS
:? No I'm not sure whats causing it.
Maybe rivet heads catching on a wire, or an earth tag catching against the flywheel boss.
This is where some stators catch, but then don't show up as a rub mark on the flywheel.
The normal easy to spot rub marks which is what it does when the laminates and\or pick-up catches the inside face of the flywheel or the rub marks off the stator bolt heads rubbing on the bottom face of the flywheel, but as you said you've marked it up and every things OK.
When you do find whats causing it let me know, Thanks...
you may have some loose magnets .....
take your flywheel of and do this easy check....
use any chunk of steel and hold it on in turn on every end of each magnet.....and as you try to pull it away ....you may notice that the magnet moves....
if they dont pull away ...they are ok .
but if they do ....and are loose ...this would explain whats happening each time they pass over a laminate end....
andylaw7
or even look at the tab that holds the wiring out the way of flywheel its been known for some people to put this on the wrong way round causing it to catch on the flywheel base . :oops:
Honeymonster
Gosh Andy, who would do that :oops:
Ian
gillykendal1
CHEERS LADS MY MATES GOING TO HAVE A LOOK AT IT TOMORROW THE LOOSE MAGNETS SEEMS TO BE A PROBABLE CAUSE AS BLACK BOX WAS LOOSE WHENE WE TOOK IT TO BITS I JUST THOUGHT IT HAD WORKED LOOSE BUT IF MAGNETS WHERE LOOSE IT WOULD CATCH THE BLACK BOX AND WORK IT LOOSE I WILL LET YOU KNOW HOW HE GETS ON CHEERS NIGEL
gillykendal1
hi sean found one magnrt loose mate how do i go about getting it fixed mate cheers nigel
others may know a method of fixing these but personally i would first try taking it back to the dealer you got it from...they should help you out with a replacement hopefully.. :D
gillykendal1
cheers mate will do
vince
my moneys on loose magnets
Tuning on the tarmac dyno of life............
