Hi Level Rear Brake Light
dapper
In the process of renovating an Injun Vijai, and thinking of converting an alloy rear frame grill to have LEDs connected to the rear brake light, hence a Hi level rear brake light. Anyone done anything like this? Gonna have to rectify the AC to DC for the LEDs, but may install a battery for the horn and rear brake light, so I have better main lights.
dapper
Hi Steve, remember your brake light under the seat. (Don't think you posted the link correctly) Thinking of mounting a PCB board with LEDs behind the slotted alloy grill ;)
yea photobucket is s**t at the mo :?
yes it is under the seat reason is i had a grill type one but couldnt get the angle of light to shine upwards very well and it was pretty dull as well this one was bright :lol: altho i was running a modified VESPA T5 stator which was giving out over 90w i got a shock off it one day when i was messing around, my arm was numb for over a day :(
theres also a second bar of 10 led,s in the main light housing you can make them out above the normal light these were about £2 a think from a car parts shop and i cut a groove in the light and siliconed them on there
dirtyhandslopez
Nice, I like it. Great safety idea too. Now get one mounted on you helmet and you'll be set. Haven't seen this done before(or can't remember) but I did see a P2 with a lazor light that came throught the horn grill.
That's not going anywhere...
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
